Same for me, but this is the first time I use the Bestfit. I understand that, for a 17-3/4 caliber, I have to consult page 150, but I can't find any resemblance.
Thank you for all your research. I learn a little more each time I use this forum 😀
23 hours ago, BlueHarp said:
I've started trying to use the Betfit, but I don't know which measurement I must take for the caliber. The diameter of the dial side is 40mm, and the other side 36,5mm 🤔.
It would be the size of the plate.
I cant find it in my books, the setting lever spring is quite distinctive i couldnt find anything like it at all.
Looked all over and I can't find it. Pity Ranfft movement identifier doesn't work.
The closest movements I've seen, from general layout, and shape of keyless are Corterbert.
I thought they were a close match to Cortebert, Nev also suggested Invar , i found a 19"' that had a very similar curved balance cock.  I looked at Revue as well but Ranfft was throwing up 404s on the pocket watch sizes.
Edited by Neverenoughwatches
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the question now, so please don't write anything related to the topic. Thank you to everyone who wrote. Have a nice day.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
