  Hello all, I had recently opened up an old Seiko from 1997 I got to change the battery, well I opened it up put the battery in and nothing works still (yes it is the right size battery). The movement looks fried and I think I need to get a whole new movement for the thing. My question is, what type of Japanese quartz movement would work for this watch? Would the one I have a picture of work?
The canon  pinion height must match the one you are removing, the physical size of the movement if it’s the same as the one removed should fit ok. The bogey hole is the height  to maintain clearance from the crystal
