I have a Memovox k815 with a dial that is only in fair condition.  I would like to upgrade the dial but can't find one for the 815.  Does anyone know if any other dials would fit like the 814?  Also I managed to break the pivot off the escape wheel.  The only replacement I can find is $500.  Again is there another movement with the same escape wheel?  If there is someone with the skill to repair the pivot please DM me.
I believe that JLC are all in house high end movements, hence spare parts extortionate prices. Sorry I can’t help with the pivot repair.
Tom
Can you post a picture?
Frank
 Could a new staff be fitted to the escape wheel ?
Edited by Neverenoughwatches
It's a pinion, so no chance of finding one separate from the wheel. Definitely less work to repivot than make a new pinion! (I generally make the whole staff for a balance of pallet fork rather than repivot though.)
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
