PNW lifer. Washington state US, for the international crew.
Just getting into this hobby. Green as grass. I used to tie Flys, but don't fish enough to ever use them all. Have boxes full of hundreds of them at this point. Make a little bit of rum and whisky from time to time.
I am not a watch purist. To each their own. I am interested in putting old beat to death dials into new watch parts. Kind of like rat rods, but watches. What I am hoping to do anyways.
If I am not out fishing, I am at the links or a baseball game.
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
