Can anyone advise how to remove the crystal from a Vertex DD case ?  I think I need to unscrew an internal retainer ?  It definitely isn't just pushing out.
Certainly looks like a ring that needs unscrewing in that photo. It definitely looks like a thread above the castellated ring as well. Separate to the caseback ring thread. It even looks to be a smaller diameter. I would expect that. Once undone out of its thread, it should fall out of the case.
Would it be possible to make a tool shaped like a letter H with one side of the H engaging the castellations in the ring and the other side of the H for you to be able to unscrew it using your hand? Making a tool with 6 'legs' to pick up all of the castellations would be a labour of love.
Edited by Michael1962
Is there a lip above that ring coming towards the back of the case ?
4 minutes ago, RichardHarris123 said:
It does look like a lip, well spotted.
Cant tell if its a lip or a section of thread. If it is lip, then i can only think that the slotted ring is spacer for the armoured crystal to push up to. There isn't much info out there about www crystals.
Generally they are popped off with air compression of a sealed case.
If you look in the notch to the right & blow that up, it does appear to just be the top ridges of the thread for that ring (smaller than the case back thread), as Michael1962 said.
Thanks for all the replies.  I'll investigate further.  I never noticed the lip and @Michael1962, I think I will have to form a tool to undo the ring and see what happens.
I'll see if I can get some more pics.
Does the lip stop the notched ring coming out caseback side ?
I sort of am expecting that ring to push against the rim of the crystal and possibly a seal against the front of the case. Hence everything comes out the back.
Nothing else seems to make sense to me. I am trying to imagine why the crystal would not push out unless the ring needs to be backed off to allow the crystal to be pushed out, but then how does the ring come out?
I am new to stripping watches though and am happy to stand corrected. 🙂
Ok.  Update.  Checked under a microscope, there is no lip, it just looks like one.  So, I'm convinced I need to back the ring out.  I'll need to make a tool of some sort.
Edited by B1N9S
🤔 so how is this relevant to the crystal coming out. I've never heard of a crystal that comes out through the back. ?
I have no idea ?  I'm new to this.  But, there is definitely a locking ring at the rear of the crystal and no detachable bezel on the front of case ?  So, I am guessing you need to back off that ring ?
There must be someone on the forum that has restored one of these ?
If the front of the case has no bezel and has an internal diameter less than the outside diameter of the lock ring, there is only one way that the crystal comes out and that is from the back.
You could always smash it and take it out the front. I’m here to help. 😉
Take a photo of the crystal side of the case.
🤔 the crystal doesn't have to fit onto a detachable bezel, it can be pressed into the front of the case. Very curious as to why there is a threaded ring inside though. I do have a record www that i could pull the movement out of but I'm away in just over an hour.
A couple of pictures of the front…
Sorry, I’m months away from this one, but…there is an edge to the bezel but I see no obvious signs of previous bezel removal and it is quite thick so it would be difficult to grab an edge on the crystal with a crystal lift. It does look like in/out thru the back…good luck…
Edited by rehajm
  • 4 weeks later...
On 5/16/2024 at 11:48 AM, rehajm said:
…then again it could be a recase.
Yes, I think yours is recased.  The bezel, the case and the crystal look wrong.  Plus it has a bracelet on fixed lugs ?
On 5/21/2024 at 8:24 AM, Michael1962 said:
How did you get on @B1N9S?
Sorry, I've not been on here much.  I tried to unscrew the internal locking ring, but in the end decided to simply keep the original crystal in situ and polish it.  Looks way better and has a nice bit of patina to it.  I have finished the watch now.  Just needs regulating, as it's running a bit fast.
So the Buren DD also has one of these retainer rings. Mine was stuck and thought I’d find something in my case back tools but most of the nibs are round and taper to the end so are too fat to reach down inside the case. 🙁
Welp, it had been over a week without buying another tool…In the states Amazon sells this Lyecun case back opener:
The nibs are the perfect fit for the notches on the retaining ring…
I unscrewed and reversed the direction of the nibs so the flat end was against the inside of the case. Worked a charm. Perhaps there’s something in your stash of case openers that looks similar?
Edited by rehajm
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
