Hello everyone. My name is Gary.
I’ve been hobby fixing for just a few months now and have turned out several Seiko 7009A, 6309 and 7s26 movements with varying success.
my first movement was a tiny Cyma 424. (In at the deep end for size).
I’m currently working on a sentimental Garret ETA 2391 for my Father in law.
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
