As I've seen multiple posts here about multiple types of cleaning solvents, I've done little more than confuse myself more thoroughly that I was before. To see if I understand things correctly...
1.  Is One dip is a solvent which is a cleaner and also a protective rinse for hairsprings jewels and pallet stones only? Or can it be used on all the parts (like the case and wheels and all the things) It seems like that would be much easier as it's just "one dip" but it is very expensive.
2. Isopropyl alcohol is a great cleaner for manual cleaning or ultrasonic cleaning (only enclosed jar) just not on pallet fork as it may loosen the shellac holding the stones. Does it have to be 99%?
3. When buying a small manual cleaning brushes, does anybody suggest a certain material of the brush itself?
Correct one dip is expensive when the chemical is purchased as " one dip " which is why it is mostly reserved for these two small parts as far as information tells us it is mostly tetrachloroethylene. I use it bought as perchloroethyl used in dry cleaning processes, i cant say I'm overimpressed with it though it appears to me to be shellac safe. What may be a better solution for hairsprings is a high lab grade of pure benzine.  IPA is mostly used as a rinse and water displacer and yes it does have the potential to dissolve shellac, personally i would not buy anything that has significant water dilution so 99.9% IPA is the way to go. And lastly the part you are cleaning dictates your choice of cleaning brush, delicate parts like a hairspring requires the finest artist's brush you can find. Plates and bridges can take a little more scrubbing, but always check to make sure the surface is being unharmed. And dont forget a stick of tip benzine soaked correctly shaped pegwood is your mate set up for cleaning dirty jewels and removing stubborn dried up lubrication.
Just to add to what @Neverenoughwatches says, the impulse jewel on the balance wheel is also held in by shellac, so avoid exposing the assembly to IPA as well - as stated the one-dip and generic tetrachloroethylene equivalent is safe with shellac so you can use this for your pallet fork and balance assembly.
I agree, but worth noting that IPA readily soaks up water, even from the atmosphere: "IPA exposed to the air will absorb moisture rapidly until it reaches an equilibrium value of 65% IPA to 35% water." So you need to refresh it regularly.
Just to add to my previous post here is some more interesting information on IPA that I found:
Source
"For a start, IPA is neither a very effective nor very versatile cleaner. IPA’s cleaning ability is limited to human body oil and iconic salts but not much more. IPA is not effective on mineral oils and most hand lotions. IPA does not clean oils and greases very well. Because fiber optics have now expanded into mining, oil fields, as well as telecom networks and data centers, selecting “the right stuff” becomes an essential best practice.
Drying speed is another issue with IPA. Slow-drying IPA can be trapped inside a fiber-optic connector. This once-pure liquid may leach out inconveniently and contaminate an endface. A familiar characteristic of any liquid is its boiling point; the lower the boiling point, the faster a liquid will evaporate. Water boils at 100 degrees Celsius and dries slowly; alcohol boils at 78 degrees Celsius so it dries slowly as well. Many companies have introduced new cleaning choices that boil near room temperature. These cleaners will “flash dry” and will not leave contamination or moisture trapped on the fiber.
IPA has another unexpected characteristic; it is hygroscopic, which means it attracts moisture to itself. Studies of 99.9-percent IPA reveal that a bottle of IPA in an open container will lose 7 percent of its strength in as little as 15 minutes. IPA continues to absorb moisture until it reaches equilibrium at about 65 percent. This is why the “rubbing alcohol” purchased at a local store is about 30-percent water. The manner in which the cleaner is packaged is critical to its performance."
