Information About A Gustav Becker Clock
GuiBer
 A friend of mine asked me some information about a clock he has inherited. As I don´t know anything about clocks I took some photos and said him I'll put them in the forum asking for some information from the experts on the subject.
Nevertheless I did some investigation, and now I know it is a Gustav Becker, but noting more. In the movement back plate, besides the GB symbol I just see a P14 and I didn´t see any serial number.
The clock as you can see from the photos, (sorry for the poor quality), has a nice wooden case with beautiful silver ( I think! ) ornament, of which you can see some details.
The clock is working perfectly, with a nice sound when passing hours and half-hours.
I would like to have some more information about posssible manufacturing year, quality of the movement and its rarity (or not!).
Thanks!
post-1304-0-17565400-1444948437_thumb.jp
post-1304-0-14129200-1444948531_thumb.jp
post-1304-0-12447100-1444948556_thumb.jp
post-1304-0-76139800-1444948586_thumb.jp
post-1304-0-00572100-1444948623_thumb.jp
post-1304-0-27614000-1444948641_thumb.jp
Hello GuiBer
Gustav Becker was a German Clockmaker. The brand merged in 1930. This clock is before 1930. It is a bim bam not just a strike on a single hammer because it has three, sometimes called a ting tang. I will call it a bim bam, on the half hour it will bim bam once, on the hour it will bim bam the amount of times depending on which hour the hour hand is pointing to. Gustav Becker prolific in turning out clocks there are so many different types of cases some bland some with nice decoration this one comes into that range. When it comes to value hard to say I would think something between  £50 - £200. The movement is an average quality for that period, yours has done well looking at the back plate I don't see any evidence of re-bushing and the dial is very ordinary. The hands are called spade.
Hello oldhippy, Thanks for the interesting information.
About the manufacturing year, perhaps if I discovered the serial number it would be easier, do you have an idea where i t should be located?
Does the inscription "P14" refers to the movement type, or could it mean the manufacturing year of 1914?
All Becker clocks had a serial number it should be on the back plate I would think near the motive. If no serial then it would have been made after 1926 but I think still in one of his factories but through a partnership. I don't think P14 is the number. Have a look here and you will see how the numbers progressed.
http://www.elitetimepieces.com/gustavbeckerref.html
  • 4 months later...
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
