A friend brought me this beautiful Omega to service. It's the first time I've seen this movement, so I'm looking through the technical guide for...guidance.
Sorry for the photos instead of text--I wasn't able to get a satisfactory cut-n-paste. The PDF is attached.
First question: are they suggesting *all* of these parts be treated with epilame, or just saying they are treated from the factory with a special coating?
Most everything else I can work out:
But my second question is this guy, from the automatic winding block. I'm assuming it's a one-way clutch, and I did not want to risk taking it apart with no knowledge of it.
So do I take it apart? How is it lubricated? I have Lubeta V105, would that be appropriate here?
Omega 1001.pdf
This guy unites the two reverse wheels in the usual system of winding movement. Do not take it apart, thow takin it apart is possible. You can get lost the small ratchets inside. I wouod use pure petrol to clean it ahd will rotate for some time the wheels when holding the pinion untill the guy is diped in the petrol. Then, after epilaming (if any aplied), I would use some Moebius 8000 solved in pure petrol and put a drop on the wheel, then will blow with air and let the petrol dry. This is old recepy not from Omega manuals where I have no idea what is the procedure.
I'm just about to clean the parts of a Cal 684 which has a similar Winding Gear (#1464). I plan to clean it in my usual way (ultrasonic with Elma solutions) then dip in Lubeta V105.
As for Epilame. The only parts I'll be treating are cap/pallet jewels and escapement wheel. I'm not splashing my precious fluids all over the place !
Did you notice in your technical documentation of 1970 it mentions this newfangled epilam stuff? One of the unfortunate problems of technical documentation is it does not magically update itself to the newest version and if it did it would disappear because it's restricted to Swatch group people only. Then there is the other problem of supplemental documentation. For instance in the late 50s in their lubrication guide they talk about epilam and practically everything in the watch. Then in the ever-changing thoughts of the day go to orally epilam adding the escapement components. But in the newest generation of stuff because epilam is less volatile solvents is more stable at room temperature they've gone back to epilam ing of the entire watch. It's actually in the last jar the cleaning machine with only a couple of things come out.
Then we're back to a Problem of time again. Yes the reverser can come apart but ideally not to destroy it you would need the special tool which you do not have. A very long time ago I worked in a shop that was Omega authorized that I was looking forward to even seeing the special tool and he didn't have it. But yes it can come apart and you really don't want to do it. I'm attaching a working instruction which came from cousins hence notice on the corners we see where it came from.  If you look on page 19 they cover lubrication of the reverser wheels. Even if and I can't remember which one one of the technical documents I have actually shows the tools explains it can be disassembled and then basically says just dip it in the whatever and be done with it and don't disassembled.
8645_WI_40_rules for lubrication cousins.pdf
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
    • Here is a method described in the watch repair book of Mark W. Wiles. Don‘t hammer, just tap very gently!
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
