Hi All, just gone to wind in the mainspring on this Rolex  cal 2236 to find that it does not have a hole but instead is flared on the end to sit in the flared part of the arbor. Does anyone know if there is a winder on the market for this as although I have not tried yet I am assuming that my standard winder will not work in this case. thanks. Any help or advice appreciated.
I have seen that some sellers on Ebay are selling mainsprings that they say are for 2235 and 2236 so again I am assuming the 2235 uses the same spring and Cousins sell a winder for the 2235  so would I be correct in assuming it would fit the 2236 does anyone know.
well after some research I have found out that this is a non serviceable part, because of the flared design, you have to buy the whole barrel complete.
I'd think it's worth trying to re-firt the spring in the barrel by hand; it's it otherwise going to be replaced you have nothing to loose!
I've managed it a couple of times, where I have not had a suitable winder.
On 5/22/2024 at 1:26 PM, nevenbekriev said:
And do You like it, do You intend to byu new barrel and give up assembling what You have?
yes, I bought a new barrel, it comes complete with the spring, arbor and lid as the original is a non serviceable item. Out of interest i tried winding the old one in by hand but it was very hard and it bent slightly so I would'nt recommend it.
I did try winding it in by hand just to see if it was possible but i ended up bending it slightly, i bought a new barrel complete which was a lot easier lol.
