Hello,
I have started learning to work on watches a week ago on an ST36.  I have the technical datasheet for the ETA 6497 and I read everywhere that one is a clone of the other.
That surprises me a bit because the bridge structure is clearly completely different (one barrel bridge which does not cover the central wheel, one gear train bridge for the center, second and third wheel, one cock for the escapement.
So what makes it a clone?  Is it the arrangement of the main plate and things like the keyless works?
Clone doesn't always exactly mean the exact copy. I have a couple links below which talk about the movement notice that also has a variety of number variations but basically they're all the same watch even if they look different. Then minor little technical difference they're not actually a clone of a 6497 because that runs in 18,000 beats per hour it's a clone of a 6497–2 Which runs at 21,600.
https://calibercorner.com/seagull-caliber-st3600k/
https://seagull1963.com/st36/discovering-the-seagull-st36-movement/
https://calibercorner.com/eta-unitas-caliber-6497-1-vs-6497-2/
Well I actually looked more into it and I think the answer is the following:
ST36/3600 is not a clone of ETA6497 it is a clone of OP XI which is a derivation of the ETA.
And when you look at both they are actually complete clones (the beat, the bridge shapes even the decoration).
One of the usual problems with clones are they may visually look right but in the case of the Chinese there will be variations. Like for instance this comes up quite a bit the Incabloc they skip a manufacturing step or two which is why the spring falls out versus the original where it typically does not come out conveniently.
The other amusing problem with Chinese watches are trying to actually identify who made the watch and exactly what it really is or is not because typically they do not put markings on them like the Swiss do.
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
    • Here is a method described in the watch repair book of Mark W. Wiles. Don‘t hammer, just tap very gently!
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
