Hi all,
I've just received this after a long time in transit. It tries to run, but obviously needs a service.
OK, open it up .... But how?
It's a plain round back, very thin edges, with no sign of a grooved area anywhere for a case knife. It also looks like someone has been trying to pry it and slipped a few times.
Is this a snap on type or a screw on that needs a friction drive to turn it?
I don't know but I suspect it's a snap back, nothing to get a grip on for a screwed back.  Try the nut method, if it's not a screwed back, it won't do any damage and you could insert a bolt and pull on that.
I just finished servicing this exact watch, and it is definitely a pry off. The divot for your case knife is hard to find, but it's definitely there. Look under good light with strong magnification.
The movement will most likely stay in the caseback, as it's kind of a tub. Let me look around and see if I have better pictures of the caseback for you.
No luck on better photos. If you're still stuck later, I can take pictures when I get home. Good luck!
Edited by ManSkirtBrew
Thanks guys, you are spot on correct - the notch is minuscule & I could only see it with magnification.
It's so small I had to use a sharp knife tip rather than a case knife. Oddly enough, it's at the end of one of the clusters of scratches!
I was slightly concerned when I took the strap off and saw "Hong Kong" stamped on the edge of the case - but's it's all OK.
I now [hopefully] have two good N510 movements, this sub second and one I posted previously with centre seconds; and both have rather tatty cases. The other is a somewhat similar that was once chrome & I was considering trying to nickel plate that, but in the meantime saw a listing for a supposedly NOS Gruen 510 case.
I got that as well, it's the one on the left below. "Vacuum" marked, octagonal recess screw back printed Gruen Guild, with a machined movement ring. I suspect it needs a special dial to suit, as the internal diameter is somewhat smaller than either of the dials on the movements I have (~28.3mm).
.... I got distracted/carried away and stripped the movement before I posted the above part! It all looks good, the only point with any visible wear is under the crown wheel edge. There is a tiny nick on an edge of the train bridge, but other wise excellent.
I'm having difficulty finding an exact match to the spare case & what movement it originally had?
The nearest I can find are the Power Glide, with a 560RSS movement and Borgel case - though that model has a deep case back for the automatic works, while my case has a flush back.
https://gruen.watch/?product=gruen-geneve-23-precision-power-glide-560rss
https://www.birthyearwatches.com/product/c1959-gruen-power-glide-automatic/
The case shape and crown detail are identical to that, and dimensions match except for depth.
The 560 appears to be the same diameter as the 510 and from the same era, so it does seem possible that it's for a less common 510 version? I just have to find an appropriate dial to suit it.
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
    • Here is a method described in the watch repair book of Mark W. Wiles. Don‘t hammer, just tap very gently!
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
