Very weird Limit pocket watch movement!
Hi,
I was given this yesterday while helping someone move stuff around for a house restoration.
The case is very poor but complete with a mineral glass crystal. There were no case screws, only the hour hand still present and the dial is wrecked - I'm guessing someone may have tried to force it off without loosening the foot screws, as the "craters" are over the dial feet.
The behaviour of the movement  is very strange! The balance wheel was very free and would oscillate for quite a while, with the escape wheel moving back & forth slightly as the pallet fork nudged it, but nothing else turning despite it being fully wound!
I've never seen any movement behave like this, so it got me really puzzled. I tried oiling the pivots at both sides in place, with no effect at all.
I then did a quick partial strip down. I though the pivot may have been bent on the wheel that carries the second hand. That looks straight - but the entire staff & pinion look black! When I removed them there was lump of something that looked charred on the plate?
Partially re-assembled & lubricated again, it started trying to run as soon as I put about half a turn on the ratchet wheel, but only just enough for the escape wheel to turn.  No different with around a half wind.
I tried a bit of 9010 on the pallet stone faces and that brought the amplitude up quite a bit - until it stopped dead.. I kept restarting it, it was barely ticking for a while then the amplitude came back up a bit, but only around half the best it was earlier.
It's very odd. I initially thought the black pinion was rust, but with the wheel out it looks more like a very deep blue, as if it had been heated?
Some of what's happened looks very amateurish, like the dial damage and blobs of mismatched paint - but I wonder if the pivot was bent at the seconds hand end and someone has straightened and re-tempered it?? The problem seems to be around that wheel & its pivots.
I don't expect it to run well without a full stripdown & clean, but with the movement problems and really needing a new case, I don't know if it will ever be anything more than a curiosity.
Hi, this is steel 'gun metal' case, so it is not a problem to grind the back and polish it, then give the case to someone who will be able to make it blackened (oxidated) again. This is a chemical process where usually the seel is boiled in NaOH at 150-60 degr celsius for several hours.
The movement is not a problem to repair, but it is a 7 jewels movement, so check the bearing holes for oval wear that must be restored. Yes, the second hand pivot has been bent and somebody has heat the entire pinion of the wheel, thus tempering it to be able to straighten the pivot without breaking it. Heating the entire pinion is a mistake, bit what is done is done. Check if the table of the wheel has gone soft as result of the heating, and if it needs truing. You will need to burnish the both pivots of the wheel and restore the bearings (and bring them to the correct places, as they can be shifted - signs of hole closing are seen on the bridge) to restore the normal function of the train.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
