Hello to you all!
I'm a jewellery maker and I volunteer for a local charity shop - taking care of all their jewellery donations. They get a lot of watches too, so I started changing quartz watch batteries and once the back was open I just had to go further... I'm gaining a new skill and the charity is gaining more income - win-win!
I'm still an absolute beginner and haven't learnt all the terms yet, but I've already seen that this will be a fantastic place to pick up tips and learn new things. The shop gets everything, from modern ten-a-penny to beautiful high quality vintage/antique watches, so I'll be looking to learn on the expendables before I move onto the good stuff. Looking forward to learning and share as I can.
Thanks, in advance!
Zelda 🤗
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
4 hours ago, watchweasol said:
Hi welcome to the forum.   Attached are a couple of documents which will add to your knowledge.  If you are into quartz watches there is another document which explains it al.  PM me if you want a copy
TZIllustratedGlossary.pdf 4.2 MB · 0 downloads TM 9-1575.pdf 14.25 MB · 0 downloads
Thank you watchweasol! Anything that can add to my knowledge is fantastic. I do get more quartz watches than anything else so I'll get in touch.
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
    • Here is a method described in the watch repair book of Mark W. Wiles. Don‘t hammer, just tap very gently!
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
