Estate Sale Find Repair
DieselBurner
16 hours ago, DieselBurner said:
 Looks to be a Hermle movement, so not too old.
Lol!  Not even close! 😆  It's a Sam Hueng movement.  A Korean firm.  So I think this is post-war, 1940-1960?  Maybe pre-Korean war since it doesn't say "South Korea?"
The chime side winds clockwise, but the power side winds counter-clockwise.  Looks like someone has been trying to wind the power side clockwise for who knows how many years and the spring was been unwound to the state you see in the pictures.  It doesn't seem damaged though, and I was able to wind it in the correct direction.
To my untrained eyes, wheel 1 does not look too bad. Wheel 2 appears to be showing some wear on the left hand face of the teeth. Wheel 3 appears to be a little bit worse than wheel 2 in the same place.
The faces on the pinion on wheel 3 appear to be rolled over/deformed as well.
I'm not sure what the tooth profile should be, but I think the wheels are showing some wear.
It might be the angle of the photos though.
This is quite common with these clocks. The problem cause the springs are so powerful but the brass? is soft so wear occurs on one side of the teeth. Clean up the bur and with needle files shape them a little but do not file them shorter as the depth will be wrong and they will not run smooth.  Your photo doesn't show it but I expect the wheel train has lantern pinions which can take wear so the pivots can be loose in there holes a little more than the fixed type. This is the style of lantern pinions.
Your untrained eye is very perceptive!  Wheel 1 isn't too bad.  It is the last wheel in the train so maybe it doesn't get as much power to wear the teeth?  The teeth on wheels 2 and 3 are both rolled a bit on the worn edge, wheel 3 more than 2.
They are lantern pinions.  I'll check the pivots of the pinions and file the burrs off of the wheel teeth.  Thanks for the insight!
10 hours ago, Michael1962 said:
The small pinion that is on wheel 3 is a normal gear pinion.
Did clockmakers mix the two types of pinion in the one movement?
The non-lantern pinion and wheel combo are actually for the motion works.  It drives the center wheel.  Both the power and chime trains (including the regulator) are all lantern pinion style.  The trundles in the lantern pinions all look to have no direct wear from the wheels - no rutting evident under magnification.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
