Hi all,
I am currently working on a tissot 2481 (equal to an omega 1481) and have tried to replace the mainspring, I ordered the correct spring from cousins but the centre spiral wasn’t tight enough for the arbour, the only option I had (with limited skills and knowledge) was to bend the spring to suit, after several attempts to get the correct size it led to the spring snapping
is there an alternative mainspring suggestion as it seems it is the cousins Swiss one I’m having the issue with or does anyone know where I can source a mainspring barrel complete?
thank you in advance
Sam
33 minutes ago, oldhippy said:
Have you looked at other suppliers. I don't know what you tried to bend it with I always used round nosed pliers.
I have had a look but my concern is I will have the same issue, I used a few types of pliers and tweezers in my attempt to bend the spring but I think that method isn’t ideal, I was thinking it would be best to have a barrel complete but I’m unsure as to the part code and finding the correct one
11 hours ago, Samspeed87 said:
Hi all,
Sam
Two ways in which i tighten up the inner coil. 1st which has always worked up to now when the spring is new or very good shape, a brass/wooden rod inside the coil to press against, i just use small pliers to manipulate the spring. The wooden rod has that extra give so you can overcompensate with your bend to allow for the steel's elasticity. If you want less breakage risk then anneal just the arbor coil, then reharden and temper when you have the shape you want.
Hi,
I've serviced a Tissot 2481 movement which had a broken mainspring, I used the following from Cousins a GR 2973X mainspring which fitted with no issues. Your issue is a common problem that is often mentioned on this site, that you source a mainspring that matches your original mainspring dimensions but on arrival the mainspring eyelet doesn't match your arbor, generally too open.
Regards CJ
Thank you all for the advice, I may have another go at the bend using the advice given, my other option is to source the barrel complete and I believe this is the tissot part 180-1, there are several new old stock around online
 light heat as i have just found out while adding a tongue to a spring . Dont re-harden and temper ( warning from nickelsilver ), all that does is anneal more of the mainspring that gets heated up while hardening.
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
    • Here is a method described in the watch repair book of Mark W. Wiles. Don‘t hammer, just tap very gently!
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
