Hi I bought this watch not working to repair because of the unusual automatic module, however I can't seem to identify the movement or Maker. The main movement is 11 1/2''' 21 jewels, the escape wheel pictured has both pivots broken
Can anyone shed any lig9.thumb.jpg.7ce725a6be24076e1289d00144f99489.jpg10.thumb.jpg.a8bbddb629ae473a3e2b39bc18584751.jpg2.thumb.jpg.9cb48177b7dafc6252435e695f9f8b98.jpg8.thumb.jpg.2580db19719ffecab4655538872b1aed.jpg7.thumb.jpg.42b137c87e7ff598612aef04c717dc5b.jpg6.thumb.jpg.55076da3cda2bec12fb6069f62539878.jpg5.thumb.jpg.64db9b3438ac30362b00868d1dc13b23.jpg4.thumb.jpg.27e0fb12a07b1f2f4334446078a95b3f.jpg3.thumb.jpg.e3cdca0b4ccf41da4f7a213cb1f9d9cc.jpg1.thumb.jpg.ad2293a88aa890305e926f6eefda1f20.jpght on the make and calibre?
The watch is for my collection and I would love to get it back into a serviceable condition but there are no identifying marks on the movement apart from the number 1 stamped under the balance cock
Edited by stylo9
Someone else posted what appears to be the same (or incredibly similar) movement on here some years ago; never definitely identified but it may add some clues?
I have a few Forster movements 80, 197 etc, they are similar but no coconut.
I also tried buying an escape wheel for a Durowe which looked very similar but again it was a bust.
Thanks everyone for your comments, hopefully someone will be able to identify it. Unfortunately then it's down to getting the part.
It's a pity because It really is an unusual automatic module and would be great for my collection
Ho hum that's watchmaking
Edited by stylo9
The Guba 1200 is a strange movement as it comes as a manual wind, automatic wind, date. and worse of all it comes as 10 1/2''' and also as a 11 1/2''' but they are all Guba 1200 calibre. the automatic was designated Guba 1200 AUT, the date was Guba 1200 CLD. But don't be fooled, the 11 1/2''' and 10 1/2''' parts are different and when buying, you will find that normally the size isn't specified. usually parts are for the 10 1/2''' movement.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
    • Here is a method described in the watch repair book of Mark W. Wiles. Don‘t hammer, just tap very gently!
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
