I recently acquired this watch. I successfully replaced the battery, but I would like to replace the badly scratched plastic crystal, and maybe the bezel. Also, the setting stem seems tight to adjust. I'd appreciate any and all suggestions. I have a basic set of watch repair tools, and am quite handy. Thanks.
For info, fine sanding sticks such as the ones below, in the high grit grades, are excellent for restoring plastic crystals (and some metal casings).
I start at 1000 grade on a crystal that has bad scratches, or probably 3000 for one that is just fuzzed with wear, then work up to at least 7000, working slightly more around the curved edge with each increasingly fine grade, so as not to leave scratches or flats/facets from only working on the main face area.
Some Polywatch or Brasso etc. after that gets it back to a perfect shine.
https://www.amazon.co.uk/gp/product/B09HZZ628K/?th=1
I find working up to 1200 grit wet and dry works fine and finish with Brasso. As long as you are light with the wet and dry and let the paper do the work, rather any real pressure put on the crystal. Here's a before and after of this Rolex acrylic crystal I polished this week just using 1200 grit and then Brasso. Circular motion of the lint free pad or bud you use.
I think the quality of the acrylic makes a difference. Some crystals won't polish well just using 1200 and Brasso and need higher grit count pastes before the Brasso
Personally, I think Polywatch for what it is, is a stupid amount of money for a small amount of abrasive that's very watered down if you compare it to diamond pastes.
Before.
After.
Edited by Jon
