Hi All
Now that I have a staking set, I want to purchase some smoothing broaches specifically for barrel arbour holes in plates and mainspring barrels.
I mainly work on Seiko movement and the average measurements are around 1mm plate hole to 2mm barrel hole.
And are all broaches tapered ??
I was thinking of this set from Cousins?
https://www.cousinsuk.com/product/0070-to-300mm-german1?code=B36688
Appreciate your advice and comments
Regards CJ
Edited by Curare
21 minutes ago, Curare said:
Hi All
Regards CJ
Yes all broaches are tapered, without the tapered length they would not broach evenly and the tapering does vary. Minimum to maximum broaching out sizes are quoted per broach.
I have a very similar one (also Cousins, also German, but 0.6 to 2.0mm). I'm happy with it and I once did a decent job (I think! time will tell..) on a barrel bridge to reduce sideshake of the barrel.
Sure, if you are an extreme perfectionist, you could argue that holes get better=straighter by having smoothing broaches with the least possible taper. That means, to have many!
But really, for Seikos you will be fine with that set from Cousins.
PS: have fun! It can be quite a bit of back and forth until you get the right hole size. Take it slow and don't get frustrated. But when you do get it right, it's a great feeling.
OH, a tip!!
What I did to help me get the hole size right was to measure the barrel arbor (at the respective position for barrel or bridge) and then use a sharpie to draw a line on the smoothing broach where it had the correct width. That saved me a lot of time.
Edited by Knebo
OH, a tip!!
You can always broach from both sides to make the hole more even. The plate and brigde holes i broach for a tighter fit than the barrel and lid.  These are not part of the unwinding only the winding as the arbor is fixed by the click and only moves when winding up.  As long as they aren't so tight as to stress the winding mechanism, the important bit is to get the friction right in the barrel so as not to rob power right at the source.
I tend to do the same, but I'm not very strict about it, given the very shallow taper of the broach from end-to-end and the 1 or 2 mm of hole you are broaching the height difference of the broach over that plate thickness is vanishingly small, I could do the trigonometry, but haven't had enough coffee ☕ yet this morning, therefore in reality I don't think it really matters if you do from one side or do 50:50..or...? I tend to do from one side, and if it needs more I try and remember to do the next bit from the other side, if I can't remember which side's turn it is I don't worry about it using the reasoning above.
The difference is likely insignificant, on a thicker material than a lid a bit more so. Theoretically you would end up with a peak in the center of the hole if you broached from both sides, which i suppose once that had worn away would leave a cylindrical hole. That possibly could be taken into account of when to stop widening the hole. In all circumstances the the finished fit is the narrowest part of the hole and will eventually wear to the widest part of the hole which is one reason why its not a lasting repair. Dont be tempted to polish up the opening as the soft brass can potentially be charged up from any compound used. Ideally a broach with as shallow taper and smoothest cut as possible to finish with.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
