Rolex Submariner (only $20,ooo on amazone) crappy dial?
@jamesb Did you get the discount offer from the Italy seller and take them up on it?
Hi i used 20mm steel bar but it doesn't have to be that thick. The connection to the motor is not threaded and is just held in place by 3 grub screws.
The VX43 Movement has a Day & Date which your watch doesn't and is a completely different size to the Y100. Edit Nearest equivalents I can find to the Y100 are a VX20 or Y320 but would need a spacer ring making. https://www.ebay.co.uk/itm/144642473798?itmmeta=01J1X57R31JFY8MQTGGAFJYVER&hash=item21ad5cff46:g:7QUAAOSwFHdizFbO&itmprp=enc%3AAQAJAAAA4CVloL5n5IJ7%2BdElMYd9%2FARJSOjUMZ0sTRjiHGA6s0%2FkQhb%2BTYSHvzsuk06bH4laWzPFmR0j6ecvShnB8%2BVVfTIq22ubCL2DoUxSYofTXW%2B3v5sD%2BnnVcoodzhJV%2BZ6bljRHx3hnAQKeXUWWpVo2y4s4ZKEsZwP2HDJKdey%2FGC90YGKWP%2BGSiSx--QUPcqB39DHPcJp%2FFoQIhoigE7y8RYAgA0Q0a2LEUtih1MsPDyMZXvK84a%2FvPm8D%2B0KjCN7ovGSdPaRQLmgdGaZ5EB14RFSbiSGUnYspi9BeK4fwjKm2|tkp%3ABk9SR8yBn6WPZA https://www.ebay.co.uk/itm/256558428698?itmmeta=01J1X5QH7MHVFVR991AKF47CBY&hash=item3bbc12f21a:g:Qn4AAOSwPbhmW7XY&itmprp=enc%3AAQAJAAAA4PkyXRpiRbdTSH4BM7xaQ%2FQG44w7PegXj4mdNMPgMYdCBX%2FRAs2OOFqJLq%2Ffx3GQjfCn6VMAuSKThAnFryx95b5O7OxvsJbCf0kafZ8j1o1yr%2B2jFnT6mq99ZPk9lwvlvRFU07dByGkiFW0yeO80mxv%2BxqxhGc2QhDPY8X%2Fc3Cs2oJr58hduHkSfJkw1GVD4tNmyMTENnRFKAJLrnwsgAY55scId8Q%2B1A96wJT7BU2LfyrdMqIAZJhDi%2Bxnfe0BOOg7Pt4MrEqg3SjBLJHeG9Qq9%2F75JKh4PUdxM76%2FTvW7W|tkp%3ABk9SR_qT3qWPZA
By Melissalea · Posted
I believe the crystals to be mineral glass. This stuff will work on that? I will look into it! Thank you. I thought the only way was using sandpaper, but since I haven't done that yet and this is not my watch I was hesitant. Also, thank you for the alternate movement suggestion. I will look into that as well. Also, thank you everyone for notes on checking a quartz movement out. I will have to find something similar.
