Having a spot of bother over finding a Cross slide that fits my Peerless Lathe. I just would love any kind of advice, Most sellers on Evil Bay haven't a clue.
I have a microscope over my lathe. It can be swivelled out of the way when needed. I find a microscope’s superior  magnification more suitable especially when cutting small items such as balance staffs
Edited by clockboy
The Marshall Peerless lathes are a little different from most watchmaker lathes. On most, the head and tailstock locate on the bed on the angled sides of the bed (as do many other larger yet still "small" lathes). On the Peerless, the location is done in the slot in the middle of the bed, which also has angled sides.
On many watchmaker lathes, the slide rest uses the aid of a part called a "shoe". The shoe fits the angled sides of the bed, and the slide rest has a recess that fits the sides of the shoe. This is honestly not the best arrangement, as there are two sources of wear and so alignment issues: the fit of the shoe to the bed, and the fit of the shoe to the slide. The former can be corrected (with a lot of work), the latter not really. It's possible that Marshall made a shoe for their bed, but I don't recall seeing one.
Some makers made slide rests that locate against the front surface of the bed. Levin, Derbyshire, Marshall, and in some cases Leinen all made slides like this. The advantage is it eliminates the two wear points above. The slide goes on, slid up against the bed, and tightened. Easy. I believe Pultra also locate against the front of the bed, and there are certainly others. This is the style you want.
This is a Marshall slide rest, top and bottom
And an American Watch Tool rest top (with shoe) and bottom
AWT later shifted to the simple locating piece like the Marshall/Levin- and went on to become Derbyshire.
Edited by nickelsilver
Cool set up, i like the mag glass on the flexi arm. Doesn't it bounce around though with the vibration ? would something unattached work better.
Edited by Neverenoughwatches
Thank you all for the help on this one. The Lathe is not up and running yet as i need to take care of a weak motor and other Di**BLEEP**elties. To me it seems as if the magnifier will get in the way a bit and as noted, have some vibration issues. I will continue a search for a cross slide, armored by the insights given.
Thank you all !
Joe
A microscope is essential in my opinion. I started out with a tiny Leitz head, single power (had to change eyepieces to change magnification) on a boom that swung it out of the way. When I got this little Leinen I found this Olympus, about the same size as the old Leitz but switchable 1x/ 2x, so 10x 20x with 10x eyepieces. It's on a post mounted to the lathe base, swings out of the way in a second, and can be repositioned over the work "by nose" as needed haha.
A lot of folks put zoom scopes on booms over the lathe; it's fine too, but I prefer this compact scope personally.
69379264188__F4210E6E-D6D4-4AF7-9A2E-35BD24C414F6.thumb.jpeg.82036df1f41196f9123eb780248037aa.jpeg
Using for watches, i will be doing Lathe work in a different room to keep the contamination down. Once i get the lathe going I think another microscope would be nice so I'm not hauling this one back and forth.
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
