Building a watch
As I am a complete beginner in watchmaking I started by breaking the first movement I attempted to disassemble (I made posts about that it is an ST 36 I still use for practicing).
I got a second ST 36 and I managed to disassemble clean lubricate and reassemble this one without apparently breaking anything. I decided that I wanted to make that movement part of a watch so I got a case, band, dial and hands from AliExpress.
So today, for the first time, I kissed a movement put a dial and put some hands. Here’s the result.IMG_0034.thumb.jpeg.e3c917ca2da4aa7b11f3eb4c48fb404d.jpegIMG_0033.thumb.jpeg.556b1a7c1d6578f6669a194a4ec4d65e.jpeg
even something as simple as that, I almost ruined it. And of course, completely my fault. I was trying to fit the movement from below and couldn’t figure out how to make it work. It actually is supposed to come from the top and the top of the case unscrews.
I almost done the top of the case by trying to pride it open, as I thought it was snapping on.
Now, as I write this post, I checked on the item description, and it is clearly indicated that the movement should go from the front and the top of the case unscrews.
Anyway, pretty happy with the result.  I think I could cut the stem half a millimeter shorter. But that scares me a bit. Maybe file it instead of cutting it. I don’t think I can be that precise with pliers .
Thanks @tomh207 indeed it made sense that one is better off with a too long than too short stem as it can be shortened but not lengthened.
I think I’ll reopen the watch and as you mention creep toward the correct length of the stem.
I’ll also regulate the watch a bit. Compared to before I disassemble and reassembled it it the amplitude seem correct but it acquired a small beat error and where it was before running at +5s per day dial up and -? (Single digit don’t remember which) sideways it is now running at -4s dial up and a -7s sideways. I think I must have moved the regulator a bit inadvertently.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
