I've just finished servicing a JLC P478.
When I got the watch it was missing the top balance jewels (endstone and cap). I ordered what I thought was the right jewels from Cousins, but what arrived was a jewel in a big brass setting with two screw holes, as if for non-shock proof movement.
So I decided to try swapping in jewels from other movements to see if any would work. I tried jewels that matched the diameter of the bottom balance jewels of the JLC- like the Seiko 6119, or Incablocs fro ETA movements, but they were the wrong depth. I ended up with the jewels from a FHF 905. They had a slightly smaller diameter than the JLC ones but they fitted depth-wise perfectly, and the watch ran.
But....the watch runs very well in all positions except for two of the vertical positions. I'm talking 290 degrees DU, DD, CD, CL, dropping to 150 degrees CU and CR.
So the first question is: could ill-fitting jewels on one end of the balance cause this?
If yes, then it would be good to get the correct jewels. I'm not familiar with JLC movements, so if anyone knows what the correct ones are then that would be great.
They would probably (pretty much 100%) be Kif jewels, and probably show issue du dd, not two vertical positions if wrong. Likely they aren't correctly centered, causing interference with the fork in those positions.
OK, but You should first say if th the radial and axial free play of the balance is OK with the new setting, does the balance not rubb in anything around... Sometimes, when radial free play has got for a reason slightly bigger, then in the vertical position where the balance is above the fork, as it gets closer to the fork, the impulse jewel rubbs in the fork arches. In such case, slightly bending the banking pins out helps. This is espacially true for hi grade moveements, where all gaps and free plays are adjusted to minimum.
It seems that the best thing would be to source the correct Kif jewels. I've checked the Cousins website and find the Kif section totally confusing. The endstone needs to be 1.5mm diameter and the cap jewel is 1.2mm diameter. On their website there's Kif 501 through Kif 584 endstones...
I've fitted the new jewels and the issue persists...
Looking at this:
i cannot feel or notice much side-shake at all. But the bad position is the one in which the balance is over the fork. The banking pins are already bent outwards about 10-15 degrees...
Well, if they are already bent (probably in the factory), does it mean that bending them more will cause something awfull?
I would check if there is 'healthy' free play between the guard finger and the guard roller on both sides and between imulse jewel and fork horns too. This will make things clear and will help to make the right decision what to do in order to solve the problem.
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
    • Here is a method described in the watch repair book of Mark W. Wiles. Don‘t hammer, just tap very gently!
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
