I found a 1998 Timex quartz diver digging through a briefcase of $10 (3 for $25) watches on the first Sunday of June (8 days ago) and found this crudy scratched timex that you could barely read the dial. It was missing an end link on the bracelet. I was able to source a new mineral flat and a pair of end links. The dial has a couple of semi circular light scratches hardly noticeable and needs a new crown and polishing of the bracelet and case. But overall I really am taken to this piece. The bezel insert shows some damage. I think the guy who owned this mixed cement a couple of times and then threw the watch into a drawer when the end link pin broke. The hands are immaculate and no water ingress has occurred. Still need a couple of things to do but I like the old scratched bezel offset by the new crystal and almost mint dial and hands. It seems to be running about a second a day or less fast. It's 40mm and 9.7mm thick. 47mm lug to lug. I like that it is not too thick and the reading of time is instantaneous!20240610_0644262.thumb.jpg.c6f2364ad6ccf58777f36ae568b76459.jpgDSCN59093.thumb.JPG.1f13912841258fe444c0051fd2c3ce0f.JPG20240610_0704052.thumb.jpg.caa315380263406fe4cf866276fe8cef.jpg
You can see what is left of the crud around the edge of the crystal where the small gap with the bezel held it in place until it hardened. The case is all SS. The bezel does not rotate but I am not scuba diving either....had to use the trick @JerseyMo describes about grabbing the winding stem with pliers and removing the crown to get this movement out of the case. These worked perfect with the offset.20240608_2137212.thumb.jpg.62323b57fbee429cac97073505f5aa6a.jpg20240609_2210002.thumb.jpg.d1bb69f61f5da7d456679249abbb3802.jpg
All in with the battery, crystal with End pieces and shipping (last 2 items from  Cousins UK) £10.99.
Edited by Razz
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
