I found a 1998 Timex quartz diver digging through a briefcase of $10 (3 for $25) watches on the first Sunday of June (8 days ago) and found this crudy scratched timex that you could barely read the dial. It was missing an end link on the bracelet. I was able to source a new mineral flat and a pair of end links. The dial has a couple of semi circular light scratches hardly noticeable and needs a new crown and polishing of the bracelet and case. But overall I really am taken to this piece. The bezel insert shows some damage. I think the guy who owned this mixed cement a couple of times and then threw the watch into a drawer when the end link pin broke. The hands are immaculate and no water ingress has occurred. Still need a couple of things to do but I like the old scratched bezel offset by the new crystal and almost mint dial and hands. It seems to be running about a second a day or less fast. It's 40mm and 9.7mm thick. 47mm lug to lug. I like that it is not too thick and the reading of time is instantaneous!20240610_0644262.thumb.jpg.c6f2364ad6ccf58777f36ae568b76459.jpgDSCN59093.thumb.JPG.1f13912841258fe444c0051fd2c3ce0f.JPG20240610_0704052.thumb.jpg.caa315380263406fe4cf866276fe8cef.jpg
You can see what is left of the crud around the edge of the crystal where the small gap with the bezel held it in place until it hardened. The case is all SS. The bezel does not rotate but I am not scuba diving either....had to use the trick @JerseyMo describes about grabbing the winding stem with pliers and removing the crown to get this movement out of the case. These worked perfect with the offset.20240608_2137212.thumb.jpg.62323b57fbee429cac97073505f5aa6a.jpg20240609_2210002.thumb.jpg.d1bb69f61f5da7d456679249abbb3802.jpg
All in with the battery, crystal with End pieces and shipping (last 2 items from  Cousins UK) £10.99.
Edited by Razz
    • Here is a method described in the watch repair book of Mark W. Wiles. Don‘t hammer, just tap very gently!
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
