Just jumped into watchmaking tho been a watch collector for awhile. My other hobby is prewar pinball which is mostly mechanical as well.
https://www.historyofpinball.org
There are some similarities between the hobbies especially with the cleaning and restoration.
I've really enjoyed working on early american pocketwatches and look forward to learning more.
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
Those pinball machines look wonderful. What is the oldest one you have. Where do you pick them up, what sort of price do you pay and what would each one be worth.
Oldest i have is 1931  Which is when modern pinball started.  Ive picked them up all over in the US and had them shipped over from the UK as well.
I like projects so im normally in the 200-800 US dollar range when i buy,
After repair and restoration they are worth anywhere up to 20k or more.   In the above pics the pricing is
1932 JuggleBall 1200$
1934 Worlds Series 3500$  (This game was sent to england with a Amusement park theme as Pleasure Island as Rockola didnt think that american baseball would go  over well)
1933 Jigsaw $4000
Heres an example of the mech under the worlds series.   The  rachet get pushed back when you load a ball.
The spring holds the tension  and the actuator in home plate releases the wheel to spin against the second gear to spin the bases.
The Star gear determines if the wheel will spin for a single double triple or homerun.
This is the latest.  It's a 1936 Rockola Alamo.  It is a payout machine and has a slot machine payout device.  I'll post the payout mech pics.  Very clockwork like.
7 hours ago, oldhippy said:
Are you going to restore it?
Oh yes. This one is going to get the full treatment.  I. Hoping to have it playable for Texas Pinball Festival  for 2026
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
