I am by no means knowledgable about clocks and watches. However, I have inherited a collection from my grandfather which I intend to restore/clean up as best I can.
The first thing I wish to do is identify them one at a time. I hope it is OK to pursue that on this forum prior to no doubt asking questions about how to do particular tasks.
I hope this is OK.
Regards
JHatton
Welcome from the U.S. Ask whatever you like. Someone will be able to answer it, and most likely, correctly. 😉
I would recommend not doing your first restoration on any timepiece that has personal meaning. Get comfortable with the tools and procedures before you dive into your grandfather's legacy.
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
