Hi everyone,
I trust you're all well.
I have a vintage hand lifting tool, it works well. I am just not sure what the purpose of the swivel screw is for. The swivel is the one where you can adjust by the brass knob.
I added pictures. The screw seems to go up and down? Is it just for ergonomics or it has a hand placing function? Anyone familiar with it? Please kindly advise. Appreciated. Thank you.
Kind Regards,
Pap3r
24 minutes ago, Pap3r said:
Hi everyone,
Kind Regards,
Pap3r
I have a few of these, i was under the impression they are roller removers, look at the tip of the center screw it has a pivot removal hole in it.
I see, thank you. Do you have a demo pic? I am having trouble visualising it.
Will do , i have i think 3 or 4 of these stuffed in a drawer all of them have this side hole . I prefer a different tool to remove rollers. A lot of these vintage tools are for pocket watches which i don't work on.  I will have a look though an old tool catalog to see what they are actually listed as , I've heard then called hand removers before.
Found it matey , yes its a roller remover. I felt it is too big for dealing with wristwatches which is why its at the back of a draw.I Iike the simple one piece bradux tool.
Wow, thank you so much. I have the other small adapter for my tool, which seems to work well for removing wristwatch hands. I'm fairly new to the watchmaking hobby, but I believe a roller remover can assist in fixing a balance wheel, correct?
Also what does the description for No. 4517 say? Got a picture further? Thank you!
The tools shown are all roller removers that is the only description, there are also prices quoted from 1899 the date of the catalogue. The 4517 is the tool you and I have, i think i have 3 of them different sizes and also 2 of the 4516 tools.
The roller sometimes needs to be removed so different tasks can be carried out to the balance ie. fitting a new staff. Always mark the position of the ruby pin so you can reposition the roller in the correct place. Its position can be worked out but its much easier to mark it before removing it.  Most folks preference is to remove the hands with levers, some may like the correct presto tool.
Thank you!
14 minutes ago, Pap3r said:
Thank you!
Thats not to say don't use this tool for removing hands, thats something you have to decide for yourself. What works for one person doesn't always work for another and tools are not always used exclusively for their intended purpose. You will know whats right if and when you make a mistake with them.
  • Similar Content
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
