My latest Russian Submarine Clock
HectorLooi
I had lunch in Chinatown today and took the opportunity to trawl a few antique shops in the vicinity.
Then I came across this beautiful Russian clock in pretty good condition. And the asking price was only $88. I didn't even bother to bargain. I just paid up and went straight home.
When I gave it a few winds and shook it, the second hand came to life, albeit a little sluggishly.
I thought that all it needed was a good cleaning and oiling was all that was needed. Just the right project for this long weekend.
When I opened it up, I was in for a shock. There was a puddle of thick brown oil inside, about the same colour and consistency of honey.
When I took off the escapement platform, I was in for another disappointment. The upper balance pivot was broken.
I proceeded to disassemble the rest of the escapement platform and did a preclean.
It is evident that a butcher had worked on this clock. The banking pins were flared ppen to the max!
Then I took a look at the pallet fork. The pivots were mushroomed almost to the point of breakage.
I contacted my usual supplier in Ukraine for Russian parts to see if he had a new platform but he has yet to reply. I hope he's ok.
  • Sad 1
3 hours ago, HectorLooi said:
Verry impressive picture, have never seen something similar. The white powder on the previous picture must be abrasive.
Actually, the clock is not submarine one. It is regular ship cabin clock. The submarine ones have 24H dial.
The parts are really big, isn't it time to attempt making new staffs for the fork and balance?
Hi @nevenbekriev, I'm thinking of replacing the whole platform. Mine is marked 4-82. The seller has 4-69, 4-71 and 4-72. Will any of them fit my clock?
The white powder was not visible at first. It only appeared after I did a preclean in 95% denatured alcohol.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
