Hello, Everyone!
I have these two vintage watches that I need to find parts for, but I need help identifying the caliber numbers in order to do so. I believe the Elgin needs a pallet fork because it has trouble running in certain positions and it looks like one of the jewels is shorter than the other. The Hamilton definitely needs a new mainspring. I appreciate any information, but if you could also explain how you figured it out I can learn how to do it myself. I tried several sites to no avail. Let me know if you need more pictures or information I have not provided.
Thank you again!!
Thank you for your information and the emmywatch website. I did look up the Elgin serial number but it still doesn't tell me what type of movement it is, ETA or otherwise. Unless I am missing that on the specs page.
Thank you very much. I really hate to be a pain, but I have searched on about 10 websites and looked at the Bestfit Book and I cannot find Elgin 477 anywhere. I need a mainspring for it so I suppose my next course of action would be to measure the old mainspring and try to find it that way?
Welcome to the forum, enjoy.. Identifying calibers is not easy but it is possible with vintage calibres if you can find and purchase “best fit catalogue”  these were the horological bibles before the birth of the internet.  Calibers are measured in lignes.
Edited by clockboy
did you look at your picture of your Elgin? I circled something for you it has letters as because it's an American-made watch
if you look at pocket watch database you'll see Elgin national watch company..  Then your grade numbe  is 447 not the number that you quoted is really important to get the numbers right if you want to get the right parts
tthen when you're on the pocket watch database side if you look on the left-hand side one of the categories is parts.. Then from the parts section llego Springs and also about the image we see the mainspring.
then notice in the bottom of the image there is your mainspring part number 1957 strength  .0045. the. But it looks like that's going to be a problem because well mainsprings are always going to be a problem. Which is why the other way always do this is take the mainspring out and measure what it is and then we can look on the listings and verify the spring in the watch is the same size and we think it is. Looks like it's been upgraded to a new part number and as usual you're only going to find one spring if you go with the modern as they don't make all the springs they once did but looks like this is your spring
4 hours ago, AndyGSi said:
Not sure if these deal with the public but it at least gives you the details you need to look elsewhere.
https://www.jewelerssupplies.com/elgin-mainspring-12-size-MS-JA110.html
I'm confused here as this is not a 12 size watch?
proper diagnostics I think is needed. In addition typically changing escapement components in vintage watches is a bad idea because they were adjusted  to each watch. Plus I see your watch has movable banking pins I wonder if anyone's ever move those? We really need better pictures to see what were looking at.. Then look at the parts list another problem typical with vintage watches looks like there were two separate pallet forks for this watch.
19 hours ago, AndyGSi said:
The Hamilton 980 is exactly what it says it is.
in other words it was made by the Hamilton watch companyanother US watch company. then I just can't do a couple of quick copy of pace and not inform you where all this came from as it's way past my bedtime and I don't have time to explain. Other than typically with mainsprings take out the old spring and measure it as things work out a lot better if we can compare the old with whatever we think were finding oftentimes especially with a vintage there could be possibly validity of variations. Then with both Elgin Hamilton they had the original steel Springs and often times they had newer alloy Springs with different part numbers and of course aftermarket would have different numbers
tthen I'm assuming this is the correct spring
then we discussed this somewhere on the group  because the type of end of spring is this or both of these have you will be extremely unlikely to dish of the spring and you're going to have to the hand wind it in or get some mainspring wagers which would be preferred and then there is a procedure.. Simplistically wind most of the spring into the wind your belief a little bit out the end dish of the whole thing in the barrel which is actually quite easy to do if you're holding a Winder and observe what you're doing  it like the end in place into its slot hold it down and pop it out and as I said we have pictures somewhere to explain this when you get your springs. Because otherwise if you try to shove the spring in the end is never going to catch  and that will be a problem
tthen you go to eBay and search for both springs  you might be lucky and find the original Elgin or  Hamilton spring and yes even though their vintage usually the originals are much better than the aftermarket especially lately where the aftermarket's seem to not be there best.
Hi to all!
I need help too ...
Can you help me identify the movement in the photos? I found this movement without the case & it is from a chronograph watch (I suspect it is a clone but I don't know whose movement). In the second photo, the rotor and wheel of the Seiko Watch Magic Lever self-winding mechanism are missing.
Thanks!
Hi. The bestfit books were up loaded by old hippy  using the term.   Mediafire. If you look that up in the search box you will find them . You will need to scroll through the list.
If not I am sure old hippy would oblige again.
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
