Speed adjust without mechanism Mantle clock
RichL
Somehow the regulating gears and lever are missing. Is there a way to adjust levers or gears to slow ti down? Gains about 5 minutes a day. Maybe add weight to the wheel (top middle)? Sorry I don't remember the proper names of the parts. 😃 I'll try to attach a picture of the clock works. Some numbers I can read are 340-020
Edited by RichL
You are the winner! I had a clock guy years ago tell me the adjustment was missing! I have the model shown in your picture with + and -, the adjustment on the balance wheel. I moved it toward the - side. Will report back in a few days how it goes. Rich
Edited by RichL
I'm not sure if you can correct 5 mins a day by turning the regulator. If you can't correct it even after turning the finger wheel all the way to the left, then you will have to add weights the the wheel. There is another video that shows how to do that.
I think I stated the amount wrong, think it is more like 5 minutes every 3 days. So far today after 8 hours it is running correct. I moved the adjustment 3 or 4 notches left. If I can't get it correct with the adjustment I'll get out my BFH
Edited by RichL
OK I have the speed adjustment set pretty good, off less than a few seconds a day. Now I am wondering if I am not winding enough is a problem? I have been winding once a week. What is recommended  interval? I have the chimes turned off.
Edited by RichL
The Hermle 340 020 is a 8 day mechanism. Winding it once a week is good. Can it run properly for the entire week?
If the clock has not been serviced recently, a full disassembly, cleaning and oiling would be advised. If you intend to undertake the task yourself, many of us can guide you through. But @oldhippy would be your bet when it comes to anything clock related. He has helped me much over the years.
You will need some essential clock repair tools like a power let down key and a mainspring winder. The mainspring winder can be rather expensive, costing about $300 to $500. So, unless you plan to repair a lot of clocks, it might make more sense to send it to a reputable clockmaker. ( Not the one who told you that the adjustment mechanism is missing. )
OK I need more help. On the adjustment on the balance wheel, there are 2 places ? !!! Is one for big adjust and one for minor adjust?? And which is which?? They are not 180 degrees from each other so I gather they each have a function. I am able to get the time close but not right, I go from too slow to too fast and back again.
Edited by RichL
I took a closer look and yes there are 2 prongs but they are the same adjustment. Thanks.
That adjustment is real touchy, seems like just moving halfway between dots causes about a minute a day change. Or like others said it might need a clean and oil. It was last done about 2012.
Regulating a floating balance is not easy if the regulator is not easy to move just touch it with something instead of using your fingers. From what I see there is no signs of dirt around the pivots but they do look dry so you could oil the movement. I have never replaced movements such as electric or battery in clocks that never had them in the first place. That is not the way I worked.
I oiled it, at least the back side, but will pull it out and do the other side if needed. I do the adjustment moving with a jewelers tiny screwdriver. Think the oiling helped a lot, now only off a few seconds a day. Will try really small adjustments from here on out. When I oiled it a couple spots had some black crud on them which I cleaned off. Thanks hippy.
Not having good results, probably time to replace. Can anyone provide Hermle 340-020 dimensions so I can put in an battery electric movement. Shaft diameters and lengths. A cheap battery movement for about $15 will make me happy. Just want accurate time, no chimes. I'll keep the mechanical movement so someday if I get the bug - I'll work on it. I want to get the new movement before removing the old so would like the dimensions first.
I just typed in Hermle 340-020 dimensions and it comes up with this.
Hermle 340-020 an FHS Hermle Clock Movement that has a plate size measuring 100 x 100 mm and a hand shaft length that measures 33 mm. This is an 8 day Westminster chime movement with 1/4 hour chime and hour strike, key wound, balance regulated and 5 hammers at the bottom.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
