Hi Alain,
My friend in England has shown me a Longines watch which he would like to have cleaned (maybe even serviced). He had some doubts about the authenticity of the watch as a watch repairer told him that it was not worth a cleaning. I am far from beeing an expert, but when I opened it I found out that the movement is a 23ZS and the case could even be made of gold!
Could someone tell whether there is a reliable watch repairer in Dorset?
Here are a few pictures
Definitely gold, with the key of Geneva stamp and a genuine movement.  "Not worth cleaning " etc is code for they weren't interested or skilled enough.  It is definitely worth a  service but I can't recommend anyone.
Who ever gave you that info is bloody stupid. As already pointed out it's 18k. Longines watches are high grade. Go here this is the  B H I site and download accredited watch repairers and look for Dorset.
https://bhi.co.uk/repairer/
Edited by oldhippy
Can I suggest that your friend contacts a few places, within the distance range he is prepared to travel. There are various different types of good watch repairer, depending on what you need - it is a very different thing to offer a competent and thorough cleaning, lubrication and reassembly, replacing any damaged parts by buying and fitting new ones, to having the skills and experience to make replacement parts like balance staffs. Some repairers build up specialist stock of old and rare parts through donor movements, often specialising in a particular era or manufacturer, others only keep the minimum of parts and buy in when needed so can only help with something that still has good availability. There are also some very variable timeframes involved - ranging from a couple of weeks to several years.
I generally have my better watches serviced and repaired, rather than doing it myself, due to my lack of experience and the value involved if it goes wrong. I currently use four different companies, ranging from a near-retired semi-professional who cleans and services my Smiths watches for £50, to someone who has good stock of rare parts for early wristwatches and charges around £250, to someone who makes replacement balance staffs if needed (although he is about to stop so I will need to find someone else for this kind of work) to someone else who is prepared to weld extensions onto broken hairsprings for 1930s ladies' cocktail watches and get the timing within 3mins/day but they are more like £600. All of them are good, but they offer a different service.
Coincidentally, one of them is in Bath, but not on the BHI list, so happy to forward details if that would be useful?
Alec
Edited by agg221
I really thank you all for your answers. My friend is very happy about that and he is determined to have it serviced.
As for me, it was a great joy to handle such a nice time piece and to help my friend.
26 minutes ago, clockboy said:
I have serviced a few Longines and they are top, quality. Certainly worth servicing.
I can second that. Where I worked we were agents for Longines I must have repaired hundreds. I had a large stock of spares as well, plus all their service manuals.
 Whaa...  I'm amazed that is even possible
So was I, but they did it. There are some extremely skilled people about, including some on this forum.
Alec
Alec
🤔 are you sure he's not pulling your leg ? I cant think of a reason why someone would even attempt to do something like that instead of just vibrating another hairspring to suit from another movement . A mainspring yes but not a hairspring surely ?
A Longines that is not worth servicing???  I concur with @oldhippy - bloody stupid advice.  I have a couple Longines and I love them both.  They are extremely accurate and look positively dashing; everything a fine watch needs to be.  And what you have certainly looks genuine from the pictures.  And it looks superb!  A service by a reliable professional should soon have it running in top form.
 Where can one get hairspring for vintage Longines. One that vibrates with the old balance is not too hard to find, but the finished product is Likely to fall short of the original's quality, then you have a Longines which used to be a Longines.
Plus the fact that used ladies Longines are not worth much, our friend gets only  " imprecise timing "   sentimental  value.
Weld?    Longines hairspring ?      Timex maybe, but not a Longines.
A CLASSICAL BODGE JOB.
Second Hand Ladies Longines 18k any thing from £1,000 you have to take into account the weight of the gold so if its heavy the price will increase a lot.
100% this.
Keep a big distance to that "watch repairer" who said it wasn't worth cleaning. Just look at the "anglage" on the bridges of the movement. Gorgeous and most likely finished by hand! That's nicer a finish than that of pretty much any Rolex you'll find.
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
