Hi Daniel,
If you go through Mark Lovick's videos on Youtube, I am sure he does one on repivoting a part of a watch movement. I just can't remember which part of the movement he did. 😞
Here is the video, but it's not a balance staff.
A new balance staff may be an easier answer.
Try turning one?
2 hours ago, Daniel123 said:
Has anyone had any luck repivoting a pocket watch balance staff?
Why do you ask, did you already try? What was your experiences?
You will see that I have repivoted useless broken balance. It is just to show that repivoting is possible and how I think  it must be done. I made the video because a friend asked me to. The right way is to turn new balance staff thow
Nice short video - without endless blabla that most others like to add.
I suppose however, a few time consuming preparations and sidework was omitted 😀
Frank
Frank
Hi Frank, I have only omitted one sharpening  of the drill bit in the middle of drilling, sizing the string to fit the hole (2-3min) and time for hardening of Locktite - 5 min.
I enjoyed the video Nev,short and to the point,  yey i made a funny 😆. This is something I've wanted to try for a long time, I'm a very long way from turning a working balance staff, so this would be my go to if i didnt have the correct staff. Actually i would have liked to see and hear some info on the dressing in of the pivot to the staff. How about modding a close sized staff.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
