Hi I'm working on this waltham 365 model I'm trying to poise the balance wheel but a notice it not even moving on the poising tool a also notice one side of balance wheel has two screws missing my question was a have few screws for balance wheel but none fit into the thread balance screw hole does it have to be a particular screw for this movement?
Edited by Murks
Thanks oldhippy does cousinuk sale any  this don't the just sale assortments does any one who could sale this?
It's unlikely that cousins would have any screws at all that would fit. Unfortunately especially for vintage watches they did not have a standards. So typically the American watch company screws will only fit other American watch company parts. So you'd ideally need a assortment of American balance wheels to look for screws.
Then the several things were replacing the missing screws you have to replace a pair of them as they have to exactly match. Also for timekeeping are we missing screws or they just rearranged in some silly fashion? You have to have the right quantity of screws for that balance wheel and hairspring if the watches going to keep time.
Then I circled something in the picture notice how two of the screws are different? I also found an image of another watch off of eBay which a paste the image below those are timing adjustment screws or mean time screws they are and never adjusted in tight. There supposed to be out some distance to allow you to fine adjust the watch. Oh they want to be really careful of these the threads on them are different than the rest of the balance screws and they don't like to be played with otherwise they get loose there a carefully designed so they can be out without turning all by themselves.
Hi Murks,
You can get one of the screws from one side and put it on the other.
20240626_103405.thumb.jpg.a178b7cfc753904bbf9a836db0e648f1.jpg.5f65ff9b83f4744da69a28e68660dc78.jpg
You say the balance doesn't even move on the poising tool, are the pivots OK?
Edited by nevenbekriev
Yes the pivots are OK have now added weight on what side and this is what I'm getting now can you let me know if this is poised
Unfortunately poise cannot be determined by looking at still images we would need a video.
If you give the balance wheel a Porsche so it rotates it must rotate and come to a stop without rocking backwards and forwards. At least if you are in school for absolute perfection that's what would happen it would just roll along and come to a stop. Oh and the jewels on the tool have to be spotlessly clean and so to the pivots. In real life the balance wheel comes to a stop they can still rock back and forth very slowly and you're going to be reasonably close. But you really need to see a video or we need to see the video of how the balance wheel looks on the tool
For instance in this YouTube video he gives the balance wheel is gentle puff of air that rotates and comes to a stop no rocking back and forth at all.
Now in this video he shows the importance of leveling the tool but even though often times the level is in the base ideally the level should be removable and placed on the jaws themselves because sometimes the jaws are not level with the base. But usually I find with my tool is as close enough but if you're really perfect about it the level supposed to be removable
Then he simulates and out of weight condition by removing a screw. Ill notice when he gives the balance wheel a Porsche it rotates but when it comes to a stop it aggressively rocks backwards and forwards. Whereas if it's reasonably close it will still rock backwards and forwards but it will be very very slowly
So really only with a video can we tell
2 minutes ago, RichardHarris123 said:
Is it the light or is this pivot bent?
Let's hope that's an optical illusion because of it is bent it will totally screw up poising as that will take control over the whole issue and make poising a waste of time.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
