I worked out a simple formula to work out how much to turn a collet. great video by Mark explaining well and showing how to set the impulse jewel between the banking pins and in the middle of the horn/notch of the pallet. If the watch is running at 300 amplitude and it is a 18,000 beats per hour, then in every second the balance would turn 5 revolutions, or 5 tics, which would equate to 1500 degrees of travel. So, 1500 degrees of travel of the balance happens in 1 second, or 1000 milliseconds, so every millisecond equals 1.5 degrees of travel. If the movement is out by 3 milliseconds the collet needs to be turned 4.5 degrees (3 milliseconds x 1.5 degrees = 4.5 degrees) If the watch runs at 270 degrees, the maths would be changed accordingly and a smaller travel in degrees over the space of one second would occur
For support, you could first try with a flat piece of pithwood. It could possibly be soft enough to push the hour wheel tube down a few tenths of a millimetre and sturdy enough not to be deformed. Then finish it off with hand levers. I've never tried it so it's just an idea.
Do you think there's space to fit anything under that hand? I'm surprised it was even running and not scraping the dial to bits.
