Who is redoing the tritium tubes
Do you think there's space to fit anything under that hand? I'm surprised it was even running and not scraping the dial to bits.
If you've got some tool steel rod, something like 2 mm, shape the end like a screwdriver and beat it flat on an anvil with a hammer it will work harden the tips and they will be really slim. Finish them off on some wet and dry and you've got some really good slim hand removers. I use mine I made for things just like this. They will find the smallest gap and open it up. I buy my tool steel from these guys https://www.groundflatstock.com/ Brilliant for making tools and parts. always good to have a supply of 2, 3 and 5 mm rod. I buy tool steel sheet from elsewhere to make things like yokes and setting lever springs. Great as collet removal tools as well! They chip every now and then but I just hone it back. I've been using these for over seven years now
The ball might work, if not you need a screw down case opener. The bench mounted ones are the best rather than the hand held ones, and the chinese clone of a Bergeon one I got was about 1/10th the price and works great.
