What material for watch cushions
…with my amateur experience I’m able to achieve that magic 270 or better so often that I do go looking for faults when I don’t. Sometimes the movement might not be capable of those amplitude numbers but quality Swiss movements from the early 20th century respond well to modern lubricants and cleaners, Seikos and a few Swiss are lower amplitude by design. The bigger question to answer is will it keep accurate time worn on the wrist? …but if you’re consistently getting those lower numbers with good quality movements I’d take the time to audit what you’re doing…esp if you replace mainsprings…
If you add the app Ublock (it's free) to your web browser, you will see no adverts at all on Youtube. I couldn't watch Youtube without it.
If you mean the sunburst, it's brushed into the dial. -
There is a hell of a lot that goes into restoring watch dials. It's not something that paint and a brush can fix. I suggest you look at a few videos on Youtube that is if you can put up with the bloody adverts. Get a downloader and it cuts the crap out.
