Hi have another question I'm still working on this waltham 365 first a notice the balance wheel was not moving freely so a decided to adjust both the jewels the upper and the lower still a can't get a proper end shake and side shake a checked both the jewels to see if the both have the end shake and side shakes the both fit  well and seem ok and right hole size  perfect a can't ad just any more of it in case both the upper and the lower jewels come out the movement a purchase this balance staff on cousinuk my question is can it be possibly that a need to shorten pivots if that's the case should a do the lower pivot first or the upper this is a balance pivot? Also on that picture going to see that a had taken out the jewels out the movement just to see if the issue where the jewels.
It a waltham 361 model 1907 the balance staff  number is : 20208 the one a had purchase on cousinuk. Cab someone check if that's right?
Info here shows a 20207 or 20208 but can't confirm what the difference is between them apart from the obvious description.
Edit
They do appear the same size so looks like it is just the shoulder that's different.
How does the new compare with the old?
20207
20208
Edited by AndyGSi
A don't have the old staff anymore the original one the one a had purchased of cousinuk is this one I'm not sure if that's the same
3 minutes ago, Murks said:
Yes a throw the old staff away a didn't reliase
Extremely important when replacing balance staffs to have detailed measurements of the old staff to verify with detailed measurements of new staff to make sure they're actually the same staff. As you've discovered classically with American pocket watches for the most part almost all balance staffs will have variation in pivots size and other times still have other dimensional differences all with the exact same part number.
Typical with Waltham lots and lots of variations. Looks like it is the 20208 Balance staff. But ideally it would've been nice to have the original to measure to see what dimensions are not quite right because oftentimes even aftermarket staffs will have variations which is why it's nice to keep the old balance staff.
Then if I go look at the staff table in the book as was pointed out up above and as usual there are pivots size variations. Which is probably why your staff does not fit the jewels as you have the wrong size pivots.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
