I finally have a replacement crown for the Longines I'm working on and I can't get the stem to thread cleanly into the crown. It goes in a fraction of a turn and stops.
Not about to force it, I tried a different stem and it threads into the new crown just fine.
The first thread looks a little smushed to me, but it could also be an optical illusion from having been filed at a weird angle.
I obviously can't shorten it to get to fresh threads, so what would you do here?
20240627203436339.thumb.jpg.6c6ebeeca7dbf3f009b234a30907c10f.jpg20240627203406806.thumb.jpg.43adcfe88fd35209a2e5b51a0402bc42.jpg
Same as Hector the correct size of die will feed on easier. Although you cant apply it in this case ( shutting the gate after the horse has bolted sorry about that and the pun 🙂 )  but a popular trick that is used to straighten out the end threads of a bolt after it has been cut is to have a nut threaded on before the cut, the nut is then spun off. For future you can use this method by trimming off the blind end of a crown and have that threaded on before cutting the stem.
Cutting it back to the root portion of the thread will help it to enter better. How thick is the crown ? If there is plenty of thread in it you might get away with a little trimming on the stem, add something in to the crown hole afterwards to stop the stem bottoming out past the required length you need. Make sure whatever you pop in the crown is small enough to come out in case adjustment is needed.
Bit difficult to do at this size, but  another idea is to clip on a halved nut and back it off the stem
Get yourself a screw thread polisher for shaving the ends
You could use a stem extender or adapter. When fitting a new crown to make sure it screws in correctly file the end so it has a bit of a point.
That usually means the wrong thread. Was the 'different stem' the same as this stem?
The threads look fine to me.
(What's the movement?)
I agree with Mike, those don't look great (I've seen way worse that still worked fine), but that shouldn't keep the crown from going on. I'm guessing the crown has a smaller thread in it.
A really handy tool is one of these plates, we always called them "Borel plate/gage", but I see Bergeon has one too. They aren't cheap, but very useful. You have male and female threads to check stems and crowns, tubes for checking crowns (the fit of the gasket) and holes for checking tubes and crown ODs, plus gages for straps.
I think you guys are onto something. The movement is a Longines 343, case #2579-343. The crown is a Longines 13WP.
I grabbed another Gruen stem I had and it does thread in a few threads, but still stops as if it were the wrong thread pitch.
I compared it (top) with the original stem and a brand new replacement 510 stem, and all seem the same. The other 510 stem doesn't thread in at all, just like the factory one.
I compared the factory crown on the left to the new one, and they sure seem the same to me. I used my microscope's measurement feature and they seem very, very close.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
