Broken Omega advice
@ JohnR725 Can you share the complete document for servicing the 1010 movement?
Thanks all, really appreciate the input. My son has just offered to take it into work, they restore pre-war cars and are used to dealing with this sort of thing, if they can't fix it I'll try OH's method.
By watchweasol · Posted
Hi given we assume you have no access to a laser welder, silver solder is the next best option but failing that the method as described by old hippy is the more common method. But clean up and tin both joints before soldering together. -
A fresh breakage I would quickly silver solder or have it laser welded. Both no more possible with soft solder on the parts.
My guess, a depthing tool. Insert whatever into the end, adjust and lock off. Check the depth of the other piece against it. Length, not depth comparison tool.
