Hi gents.
So, my lady sometimes wears a Camel Trophy watch that runs on batteries powered by an ETA 955 412 movement.
The watch began having trouble setting the time, although it sets the date just fine.
I opened it, took it out of the case and began removing the hands so I could remove the dial and take a look at the keyless works, but I can't seem to remove the hour hand. The hand is too low, it's touching the dial and my hand removing clips can't sneak underneath to pull it. Anyway, I loosen the dial feet holders and took the dial off, thinking that by doing this, the hour hand would come off, but no... I noticed the hour wheel got stuck too on the back of the dial.
Now, I'm afraid that whatever I do to try to get these off will somehow damage them...
Any suggestions?
Thanks!
14 minutes ago, RichardHarris123 said:
Maybe someone could give you better advice but I would make a support, same size or larger than the dial, drill a hole just bigger than the hour wheel and then push on the hour wheel pivot.
Yep, that's how I would do it
If you've got some tool steel rod, something like 2 mm, shape the end like a screwdriver and beat it flat on an anvil with a hammer it will work harden the tips and they will be really slim. Finish them off on some wet and dry and you've got some really good slim hand removers. I use mine I made for things just like this. They will find the smallest gap and open it up.
I buy my tool steel from these guys https://www.groundflatstock.com/ Brilliant for making tools and parts. always good to have a supply of 2, 3 and 5 mm rod. I buy tool steel sheet from elsewhere to make things like yokes and setting lever springs.
Great as collet removal tools as well!
They chip every now and then but I just hone it back. I've been using these for over seven years nowhandlever2.jpg.a328493c5775b58743e1b3ff1fdbd354.jpg
Edited by Jon
Do you think there's space to fit anything under that hand?
I'm surprised it was even running and not scraping the dial to bits.
For support, you could first try with a flat piece of pithwood. It could possibly be soft enough to push the hour wheel tube down a few tenths of a millimetre and sturdy enough not to be deformed. Then finish it off with hand levers. I've never tried it so it's just an idea.
My hand removal tools are crap. I ordered them through Cousins and the tips are too thick. They did remove the seconds and minutes hands because their height from the dial ground is greater than the thickness of the tips.
I have several hones from 350, 1000, 5000, 8000 and a natural Belgium Coticule with unknown grit, probably around 10k~12k. I might grind them and file them a bit until the tips are flattened. It will be difficult since I don't have anything to lay the tools to get a fixed angle and hone evenly, but I'll figure out something.
Anyway, as much as I file the tips and turn them into a really slim wedge, this won't be enough to stick under the hour hand.
Thanks for the idea! I'll definitely will grind the tips to turn them into a proper hand removal tool.
The dial did looked marked where the hand was tight. If there is a little space between the hour hand and the underside of minute hand then the hour hand will lift slightly with only the resistance of the dial washer. Should be just enough to get something thin underneath, a mainspring bend ?
Edited by Neverenoughwatches
  • Similar Content
    • @quantieme, I feel I need to say few things more than the others already sid here. The auto winding module is a simple thing and finding faults in it is simple thing too. But You need to know how it works and what must it's behavior be first. First - how it must work and what and behave when it is in normal order: You have  traditional bi-directional winding module with two reverse wheels, but here in Omega the two reverse wheels are united in one, they are two reverse wheels mounted on one common pinion. Then, I have seen in some Omega movements that You have one more reverse wheel, which is mounted on the ratchet wheel. The ratchet wheel is made on two levels, with reverse function between them. This allows separate winding by the crown without bringing to motion of the auto module.  I am no sure if You case is this, I have not worked with such movements long time ago, have only distant memories. You have to know how normally such auto module performs as to check and understand if there is a problem with it. When the spring is not wound, turning the rotor in any direction will slowly turn the ratchet wheel, and You will fill almost no resistance. Turning the watch will make the rotor turn the module because of the rotor mass. BUT when the spring is already wound, You will fill significant resistance when turning the rotor , and slow turning of the watch may not make the module turn, as the mass of the rotor may not overcome the resistance of the spring winding. This is the reason why some movements will not auto wind fully on winding machines. But it is important to know that in this condition (fully wound mainspring), turning of the rotor in any direction must continue turning the ratchet wheel (actually the arbor of the barrel, as there might be reverse wheel in ratchet wheel that may be out of health). Further more, a healthy module will have relatively small angular free play of the rotor. This will be about (no more than) 90 degrees. And, if You turn the rotor only to +/-180 degr., this must be enough to make the ratchet wheel turn. So, here You have the way to check the function of the winding module. No use to check it's function when the spring is sunwound, as then resistance is small. Wind the mainspring fully (6 revolutions of the ratchet wheel is enough) and start turning the rotor back and forth in the limits of 180 degr angle, not making full revolutions at all. Observe what is the angle wit small resistance (the free play) and is the resistance increasing (spring is wound) within the limits of this 180 degr. oscillation. Does the ratchet wheel turn ahead? Of course, as @oldhippy said, the main reason for faults here id the double reverse wheel part. If it is out of order, usually disassembling it shows that one of the posts of the pawls inside has broke or smash. Replacing of the post (tapered steel pin needed to be pressed in place and then cut and filed to correct height) normalizes the function of the part. But, if there is reverse wheel in the ratchet wheel, it may be the reason too.
    • When you say stuck movement, does the weight still rotate and wind the barrel (don't try too hard if it doesn't want to move)? It could be the fourth wheel that's moved so you may need to remove the bridge or at least loosen the screw again to re-engage. Edit Maybe best just to remove the bridge if you can and check the pivot or teeth aren't damaged.
    • Good thinking, I'll drop them a line and let you know what they come back with.
    • Hammer time can cause some burrs, so don't forget to check for those after using the smoothing broach.  A large size Seitz reamer is perfect for removing burrs.
    • The stoppage started day three after crystal replaced. Final adjustments made prior to stoppage were as followed: 1 made minor adjustment to move the rate lever to the negative side in effort to slow it a bit. 2 closed the watch back up. 3 did the Seiko wobble and noticed a different sounds of metal on metal. 4 reopened the back and found a screw had backed its self out. Tightened the screw and now stopped or stuck movement. All was in working order prior.
