I always use a large size reamer to clean the edges after reducing the hole size.
Such a short distance away have you ever thought of visiting as I think it is open from time to time for visitations. Then I'm pretty sure they used to have a yearly big event that always looked really interesting no idea when that would be though? I assume if you're going take a distance learning course is there a list of what this course actually covers? It would be helpful for us to evaluate if we actually knew what the course listing Is which it seems like they should have somewhere?
Hairdryers works surprisingly well. They blow hot air which is perfect for driving.
Interesting pictures on the timing machine? The problem with timing machine diagnostics is it's missing information a lot of times? Like for instance all the questions that were asked up above would be helpful for us to understand what's going on. Then the classic question I like to ask is what is the prior history of the watch? Was it serviced before you is a brand-new movement and then there's probably a dozen other questions but we just need more information timing machine looks good in one and bad and the other and that's not enough to understand the problem other than it's definitely looking bad oh and when you have what's called the snow globe effect the numbers are worthless also they mean nothing. Oh I did think of a question when it's doing that how long does it do it and if you change the position of the microphone like I assume this is dial down changing to another position does anything change at all?
