Hi how can I make the palette stone in centre with the escape wheel teeth ? I mean the escape will teeth in line of Center with the pallet stone. That's what We meant to do but I don't know if I should adjust one of the Jewels?
By watchweasol · Posted
Hi all the speculation in the world is not going to fix the problem it’s going to have to come apart carefully checking as we go. Hectors advice is best followed first as it’s the least invasive. Just power down the movement remove balance and pallet then check the train for freedom , if still stuck the bridge will need to come off to go further. Take pictures at every stage and ant notes that may be aplicable -
Yes the classic problem of watch repair it takes time to learn. Going to school is all about practicing continuous practicing and when you get out of school were still practicing we are forever practicing. The other thing that comes to play is what exactly is the balance staff made out of? Then have you hardened it at all before cutting?
My personal favorites is at four minutes and 54 seconds. The machine with how many parts? All before CNC on the other hand if they Needed to change the tooling to a new watch plate how long would that take? Then if you like the movie there is a book different watch company few years before but still it talks about the tools or some of them https://archive.org/details/evolutionofautom00mars_0
