I have a few Armani watches that need new batteries. I have to pry open the back case.
I bought pry opening tools from ebay. These are useless. They scratch the case and opening is mission impossible.
I went to a local shop. The guy there opened the back cases for me. He had a pry tool that was slightly bigger.
He opened - but still had to scratch the case underneath slightly.
What I need: some sort of clamp to hold the watch in place (without breaking) and then to place a pry tool and apply pressure.
Does anything like that exist??
OK... but then I need to close the battery. I have a clamp I bought from ebay. It takes me a pain staking 20 minutes trying again and again to close the back cover. I'm sure I'm missing simple instructions.
I suspect I need more quality tools. I'm happy to invest in buying if needed. I've search loads and can't find anything different to what I already have!
Hoping someone can offer helpful advice.
Thanks.
  Pry as usual only place a piece of thick paper or cloth
 on the case underneath your pry tool
the paper will cushion and prevent scratching.
Some back plates ,by design,  are to be pressed with pressing tool. There are pressing tool of different quality at various prices, and undoubtedly relevant discussion on WRT forum.
Usually watches get ruined by watch repairers.
Rgds
Edited by Nucejoe
corrections
Thanks for the replies guys.
@Nucejoe
>> "Pry as usual only place a piece of thick paper or cloth"
No! it's not that easy surely! 🙂
I've tried loads and loads. Would be amazing if you could give me a video link of someone who's doing it?
@tomh207 in terms of case vice... those look  like you need to hand hold?
the press in the video looks pretty awesome
I've attached 3 pics... would these be any good?
I found oniline. Both about £12.
Thanks.
I like that you have a procedure you know what you're doing or do you? I don't suppose we can have a decent picture of the back of the watch and a side view of the watch?
The case opener in your first picture is for Rolex style casebacks.
The case holding vice in the second picture is cr*p. The moment you start turning the caseback, the entire vice would turn together with it.
The crystal/caseback press in picture three would probably work. But you have to make sure that the screws of the upper and lower tool holders are properly aligned. Some of them don't line up properly.
If you're using a traditional caseback knife or a Swiss Army knife, you're chances of slipping and scratching the caseback is very high. No paper or plastic sheet will be able to protect the surface if you slip. The secret is not to slip. 🙄
A Seiko style caseback knife is less likely to slip. It is used with a stabbing action to wedge the blade under the caseback. Don't try to pry/lever the caseback off like a tin can, that would only lead to slippage. The wedging action would pop the caseback off in most cases. Only in really stubborn cases where the blade has wedged in but the caseback still hasn't popped off, then some twisting and levering is permitted to lift caseback to pop it off.
Very rarely, you'll come across some really tough casebacks that would require specialized tools to open the watch. But we'll leave that alone for now.
What @HectorLooi has said covers most of your ask but I’ll throw in a couple more bits.
my, and most case vices can be used in a bench vice to give you extra stability or be hand held.
what he was trying to get over as well is our natural tendency is to twist the tool to open the back, this is not the way to do it but using the tool to wedge the back off is.
Tom
Modern ashion type casebacks can be difficult to open, the seams can be extremely tight. I use one if not two razor blades to work around the seam, no or very little prying though even when tempted, the tool's edge will dig into the back or the case itself. Better to use a thicker blade to wedge in and avoid working near the crown you're sure to lever off of it if its there.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
    • Yes that's the type @watchweasol is referring too but I don't like them as you don't get any feel to what's happening.
