Just now, PastorChris said:
Im just going to sit back and watch in awe as you folks speak about things I know nothing about.
Yeah, this has moved from a "watch" forum to an "electronics" forum.
But, hey, there are a few guys on here that have a healthy understanding of electronics!
30 minutes ago, LittleWatchShop said:
All of your connections to the flood fill should be with thermal pads to make life easier.
Like what I show here.
How do I do that?  Can't find in express...
25 minutes ago, LittleWatchShop said:
I don't see any other mistakes.
Should I add this capacitor also?  I didn't think I needed it.  It wasn't on the original schematic, I had added it because the data sheet for the rail splitter showed it....
52 minutes ago, LittleWatchShop said:
Yes, but plan for a bigger cap...maybe 1uF...it lowers noise
How does this look, I added C14 and used heavy traces for the grounds....?
image.thumb.png.3dca6e60c8e8cd6c290e6bbc7b37280a.pngL
35 minutes ago, LittleWatchShop said:
You never fixed this issue and I missed on subsequent reviews
I followed the schematic below....  Supposedly he got it working like this....  It is a LT1115 and he is using it as a buffer not amplifying with it.  The rest of the OP amps are 5534s.  This schematic is from a previous post several pages back...  It is a modified version of the watchOscope one.  (Which I did make last week)  I am making several difference ones to see what works best.  I am using a modified microset as a preamp right now in my diy setup which works quite well.
37 minutes ago, LittleWatchShop said:
You should link the schematic to the PCB and verify each connection
I created the schematic in TINA which I thought wouldn't work with Express...
1 is not equal to 2.  Go back and carefully look at the datasheets for these parts and look at your schematic.
LOL! They are all wrong...  I swaped 1 and two on all of them..  Oh my.. LOL!!!
I think this might be better.image.thumb.png.7e76191574cca4bf3c2e888d8e3a6714.png
There is a major error in the schematic, it will never work this way ? :
negative supply pins are connected to +4.5 V and +inputs of NE5534 are connected to 0 V!!
Another question, to what input are you planning to connect your preamp? Will it bear an output signal of 0.75 to 75 V_peak (theoretical - there will be clipping of course)? For what do you need that ambitious amplification of 7500x ?
Frank
Frank
Thank you...  Please tell me how to fix.  Looks like I have 9v at neg supply.  image.png.2c4a6a55c87f28bcf242ae7de0461a6a.png
UpdatedOpAmp.TSC
In fact you have. I wonder if you already blew your ICs?
You should connect:
+9V to V+ pins
0V to V- pins
4.5V (TLE2426) to +In pins.
...and think about my 2nd question.
Frank
Edited by praezis
  • Similar Content
    • This is indeed a unique site and members including myself genuinely care about it.  All we want is the site to continue.
