Greetings from Clinton, Indiana
Hi Mike I did a ships clock a long while ago, not a Hermle though and without getting the beast in my hands to refresh my memory I canāt recall the timing. Ā This doesnāt help I know but will start the grey matter turning. -
I have stripped and cleaned a Hermle ships clock. It was just oily, no major faults, and I reassembled it, following my photos in reverse order. The time train is fine but the strike train will not play the ships bell strike for half-past. Ships bells play a four hour sequence for the 'watches' and play double 'ding' for the hour and the double dings plus one for the half past (eg half past the second hour is 'ding-ding' 'ding-ding' 'ding'). Sounds complicated but it isn't really. The strike wheel consists of pairs of bumps (for the ding-ding) and no single bumps. There must me some mechanism on the half-past that lifts the strike lever over one of the bumps so only one ding is played. When I get to a half past, it still plays double ding. I have a feeling it is to do with the lever in front of the rack (there is a sprung attachmentĀ on it) and the position of the wheel (to the right) with the two pins that lets that lever fall, but no matter where I place that wheel I cannot get a single ding at half past! Please can someone help with advice on positioning so I can fix this? BTW Happy Easter š£Ā
I think it would rather be the blast of high current drain that would do the damage. But if used occasionally to maybe fix a mainspring or do dial feet it might be worth trying especially if the mainspring or a replacement couldnāt be found.Ā Ā Tom
