Anniversary Clock base
Michael1962
Hi everyone,
I am still trying to find a decent one that I can acquire. Found one in a local antique sort of store. They are asking too much I think, especially due to the fact that the base is cracked.
I will try to explain what I saw.
The circular base has two 'rolls' for want of a better word before it gets to the top surface of the base.
The crack on this base runs at 90 degrees to the two 'rolls'. From the bottom edge of the base all the way to the top horizontal surface.
The reason I am asking is that I am wondering if the base of an anniversary clocks is brass or are they another base metal, steel?, with brass plating? If so, this clock base may be repairable. I can't remember what brand it was. Sorry.
If they are brass plated, how do you replace it so that it has a mirror finish? I have seen a couple of YT videos where the person is mechanically plating by heating the part to be plated and then vigorous brushing with a brass brush which mechanically plates the steel. However, no-one seems to answer the question of how to get a mirror finish.
Is a mirror finish only possible with electro plating? This question is in respect to another clock I have found in South Australia and the base is showing a lot of signs to suggest the brass coating is flaking off. This one is cheap compared to the one with the cracked base in the shop in Geelong.
https://www.ebay.com.au/itm/305654992071?itmmeta=01J23BGZFPX3T9M0KW0JMFRHSQ&hash=item472a750cc7:g:0U8AAOSwPrdmhosh&itmprp=enc%3AAQAJAAAA8EZZWbbe5OzksPlS07pedENWjUwQr7W76uvFqXK6xGvVsKzeIrnXrADMGJ6yFIY4yhnuHyHnwhL1Jzc1iJvrvtnwQcDIrBR4D8ohZGFMOOdYqFEOUZ84v4IfX3i9zGofPLjWTjZg8GIXyabw%2BvMEv4kOGnaoyUweBisAHxuiz5krNTYB6EmO62NFEchTcXtEPgj4wObzxr9wrYRaNA%2Fr9AfuXmM7vhmziVWhasZJcLcIc9A4D4zmfL%2Bktz9TXknAVWPbngL3u7p8ZlmtC%2FknQVFbLoVKk2xJ69omIblJ07OwHj6oXYrtdq3fZ5%2BNspWjZw%3D%3D|tkp%3ABk9SR_T3w-uQZA&autorefresh=true
Any & all answers are appreciated.
What the hell happened for it to have a crack in the base. Some have what I will describe as a wooden filler but not that many. If I were you I would leave that one. The one on ebay for the base lots of elbow grease very fine steel wool, you need to check for lacquer first if it is then laquer thinner then wash in soapy water but a again check to see if the base has a filler, if so be very careful with washing.
That base is a mess, most early bases had solid spun brass but later ones tended to be very thin brass skin over a steel substrate and a lot have as oldhippy said a wood infill & very few had brass plate.
Dell
The clock you were looking at is  a ( Kieninger & Obergfell ) Kundo for short the base is Gustav Becker although it may fit as long as the pillar mounting holes are in the correct place the dome may not fit as the GB looks to be pre WW1 the clock is 50’s , that Kundo is not the best of quality my advice would be look for a JUF or Schatz ( same company) preferably pre WW2
There is a Schatz1000 day carriage clock for sale on eBay runs for three years on one wind quite rare in uk, I have one but with glass dome even rarer .
Dell
Edited by Dell
Forgot something
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
