12 hours ago, nevenbekriev said:
escape wheel is easy as as piece of cake
Thinking about how incredibly easy it is for you to make everything related to watches may be used should think of going in a new direction?
https://en.wikipedia.org/wiki/George_Daniels_(watchmaker)
Then there is somebody who followed in George's footsteps. Rogers a very interesting person I've actually met him twice I found him quite interesting and look what he's done with his skills. It does appear from what I'm reading that you beat these guys out So I was thinking maybe You should start making complete watch. Almost anybody can fix the watch but your skills are going to waste if you're not making a watch a complete watch
https://www.rwsmithwatches.com/
Here are two pictures and the video
On the pictures You will see the original damaged table of the wheel and the one that I have cut with the help of milling attachment on the lathe.
IMG_20180207_144112.thumb.jpg.b31e427bd7d70d0f77a8fb1c214d51f7.jpgIMG_20180207_145820-Copy.thumb.jpg.8956885ce60cfe80e1cdcd7fbd2908ce.jpg
The video just shows how the movement works with the new wheel:
By the images and video names You will see that this has been made back in 2018.
I must explain some steps of the making as they are important and are not seen as the images are not enough to explain everything.
First, the new table is made with a little bigger diam than needed, and the teeth tips are not sharp as they must be in the end. The cutting here is simple process and is made with one passing only with shaped by hand cutter to give the form of the teeth as shown. The rough table then is riveted to the pinion and engagement with the lever (the drop lock) is examined on depthing tool. Then reducing of the diameter by grinding with fine diamond file while rotating the wheel between centers (in turns) is done untill the desired drop lock is acheaved. This is because in english lever one can not regulate the depth by shifting pallet stones. Finally, sharpenning of the teeth by hand filing the rear surface of the teeth is done until the tips get almost sharp (just verry small plates left on the tips)
👍  Awesome.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
