Hi
The crown wont turn anti-clockwise as well as not able to pull out to set the time.
The push button to release the crown is super stuck as well.
Any idea how to proceed from here?
Is the crown wheel screw to be turned clockwise or anti clockwise??
Edited by Khan
You could put some penetrating oil on the setting lever release and between the crown and case. yes the crown wheel should be anti-clockwise, but also looks like there may be some rust on it, as I suspect there is water ingress from the crown.
Ok I will try that thanks.
Just to be sure, do you mean that the crown wheel screw should be loosen by turning it anti-clockwise?
Yes, the screw in red "should" be but I have run into a few that are not. But looking at the marks on the screw, it confirms that its reverse threaded. This is where the last watchmaker used a little too much torque, so it might be harder to get off
Yes...you guessed right - there is definitely some rust! I only need to loosen the setting lever release button from the plate and the winding pinion from the stem. Any tips?
I use a rust remover made from 5g EDTA powder in 100ml deionised water, plus a drop of washing up liquid (dish soap). It's not fast, but it does not affect the base metal.
These are some bits I've just done, from an old wooden case I got to store some watchmaking tools; before and after an overnight soak. The residual light brown marks are from me not drying them properly (plus the box was originally varnished after the latches were added).
I use the same mix on watch parts and old tools, and it works equally well:
Guess what..
I managed to pull the stem out with some force and a "stem-holder". I began with soaking it in vinegar up to couple of hours which didnt work that much.
The pinions are luckily quite crisp in the teeth and so on. The stem thread got a little thinner after scraping the rust away but seems to be strong enough in construction.
For the cost of it I think I'd just replace the stem anyway.
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
