Elliot Clock, No Tick Or Chimes.
Geo
I had a nice wee change today, a friend asked me to see if I could get his fathers old Elliot clock running. It could probably do with a complete strip and clean, but I'm way too busy to do that just now.
It was an easy fix to get it going, both the crutch and the pendulum needed a slight bit of tweeking. Someone has been at it in the past, and was a bit heavy handed. The crutch required very little bending to sort, but the twist and bend in the pendulum required a little more effort.
The Westminster chimes wouldn't work because one of the actuating levers that is driven from a cam was completely in the wrong place. It was an easy fix, after I worked out how it should operate. Another issue was someone had bent the click spring on the right hand barrel, thus preventing the chimes barrel from being wound. Again it was an easy fix. When the movement was fitted back in the case, I tweeked the hammers to get a nice clear sound.
After a touch of oil in the relevant places, it's now ticking away and chiming as it should!
post-124-0-80613600-1445958235_thumb.jpe
post-124-0-40013900-1445958284_thumb.jpe
post-124-0-61525100-1445958335_thumb.jpe
There good movements these Elliot's I have two platform escapement timepieces. If I remember correctly with the chime movements you can remove the barrels without taking the movement apart, very handy if the springs break and theirs no other damage. The whole movement is very simple to work on. Well done George it looks as if it needs a clean so you can always have it back in when you have less on.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
